При попытке вызова любого телефонного номера после набора производится сообщение: "набранный номер не может быть вызван"
Входящие работают
Провайдер говорит что никаких ограничений нет
В VERBOSE при наборе фиксируется это:
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:1] ExecIf("PJSIP/201-00000013", "0?Wait(0.2)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:2] ExecIf("PJSIP/201-00000013", "0?ChannelRedirect(,all_peers,,1)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:3] ExecIf("PJSIP/201-00000013", "0?Hangup()") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:4] Set("PJSIP/201-00000013", "cleanNumber=89137900700") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:5] ExecIf("PJSIP/201-00000013", "0?Goto(all_peers,89137900700,6)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:6] Set("PJSIP/201-00000013", "__FROM_CHAN=PJSIP/201-00000013") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:7] ExecIf("PJSIP/201-00000013", "1?Set(__OLD_LINKEDID=mikopbx-1676521508.27)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:8] ExecIf("PJSIP/201-00000013", "1?Gosub(set_from_peer,s,1)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:9] ExecIf("PJSIP/201-00000013", "0?Gosub(set_orign_chan,s,1)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:10] ExecIf("PJSIP/201-00000013", "0?Set(CALLERID(num)=201)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:11] ExecIf("PJSIP/201-00000013", "0?Set(CALLERID(name)=201)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:12] ExecIf("PJSIP/201-00000013", "0?Set(__FROM_PEER=201)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:13] Set("PJSIP/201-00000013", "CHANNEL(hangup_handler_wipe)=hangup_handler,s,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:14] Gosub("PJSIP/201-00000013", "dial,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx_lua.c: Executing [89137900700@dial:1] CELGenUserEvent("PJSIP/201-00000013", "eyJJU19PUkdOVCI6ZmFsc2UsIlVOSVFVRUlEIjoibWlrb3BieC0xNjc2NTIxNTA4LjI3XzhWNEw5MyIsImFjdGlvbiI6ImRpYWwiLCJhZ2lfY2hhbm5lbCI6IlBKU0lQLzIwMS0wMDAwMDAxMyIsImRpZCI6IiIsImRzdF9udW0iOiI4OTEzNzkwMDcwMCIsImZyb21fYWNjb3VudCI6IjIwMSIsImxpbmtlZGlkIjoibWlrb3BieC0xNjc2NTIxNTA4LjI3Iiwic3JjX2NhbGxfaWQiOiIwXzEyMTM0MzM5MDZAMTkyLjE2OC45LjIxIiwic3JjX2NoYW4iOiJQSlNJUC8yMDEtMDAwMDAwMTMiLCJzcmNfbnVtIjoiMjAxIiwic3RhcnQiOiIyMDIzLTAyLTE2IDExOjI1OjA4Ljc5NCIsInRyYW5zZmVyIjoiMCIsInZlcmJvc2VfY2FsbF9pZCI6IltDLTAwMDAwMDBkXSJ9")
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx_lua.c: Executing [89137900700@dial:1] UserEvent("PJSIP/201-00000013", "CdrConnector,AgiData:eyJJU19PUkdOVCI6ZmFsc2UsIlVOSVFVRUlEIjoibWlrb3BieC0xNjc2NTIxNTA4LjI3XzhWNEw5MyIsImFjdGlvbiI6ImRpYWwiLCJhZ2lfY2hhbm5lbCI6IlBKU0lQLzIwMS0wMDAwMDAxMyIsImRpZCI6IiIsImRzdF9udW0iOiI4OTEzNzkwMDcwMCIsImZyb21fYWNjb3VudCI6IjIwMSIsImxpbmtlZGlkIjoibWlrb3BieC0xNjc2NTIxNTA4LjI3Iiwic3JjX2NhbGxfaWQiOiIwXzEyMTM0MzM5MDZAMTkyLjE2OC45LjIxIiwic3JjX2NoYW4iOiJQSlNJUC8yMDEtMDAwMDAwMTMiLCJzcmNfbnVtIjoiMjAxIiwic3RhcnQiOiIyMDIzLTAyLTE2IDExOjI1OjA4Ljc5NCIsInRyYW5zZmVyIjoiMCIsInZlcmJvc2VfY2FsbF9pZCI6IltDLTAwMDAwMDBkXSJ9")
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx_lua.c: Executing [89137900700@dial:1] return("PJSIP/201-00000013", "")
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:15] GosubIf("PJSIP/201-00000013", "0?all_peers-custom,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:16] GosubIf("PJSIP/201-00000013", "0?applications,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:17] GosubIf("PJSIP/201-00000013", "0?internal,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@all_peers:18] GosubIf("PJSIP/201-00000013", "1?outgoing,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:1] Ringing("PJSIP/201-00000013", "") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:2] Set("PJSIP/201-00000013", "src_number=89137900700") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:3] GosubIf("PJSIP/201-00000013", "0?outgoing-custom,89137900700,1") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:4] ExecIf("PJSIP/201-00000013", "0?Hangup()") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:5] ExecIf("PJSIP/201-00000013", "0?Gosub(transfer_dial_hangup,89137900700,1)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:6] ExecIf("PJSIP/201-00000013", "0?AGI(check_redirect.php,)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:7] ExecIf("PJSIP/201-00000013", "1?Gosub(dial,89137900700,1)") in new stack
[2023-02-16 11:25:08] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:8] Playback("PJSIP/201-00000013", "silence/2,noanswer") in new stack
[2023-02-16 11:25:10] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:9] ExecIf("PJSIP/201-00000013", "0?Playback(followme/sorry,noanswer):Playback(cannot-complete-as-dialed,noanswer)") in new stack
[2023-02-16 11:25:12] VERBOSE[58559][C-0000000d] pbx.c: Executing [89137900700@outgoing:10] Hangup("PJSIP/201-00000013", "") in new stack
[2023-02-16 11:25:12] VERBOSE[58559][C-0000000d] pbx.c: Spawn extension (outgoing, 89137900700, 10) exited non-zero on 'PJSIP/201-00000013'
