Исходящий звонок проходит, входящий нет
Здравствуйте,
при попытке позвонить на номер 4954190314 - ответ номер не в сети
логи
3-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 2552958968) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 251769860) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 251769860) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 456699399) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 456699399) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 4221724727) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 4221724727) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3827016737) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3827016737) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 1599827676) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 1599827676) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3709979522) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3709979522) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 2552958968) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 2552958968) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2582414048) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2582414048) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 456699399) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 456699399) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 4221724727) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 4221724727) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2582414048) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2582414048) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 251769860) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 251769860) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 2552958968) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 2552958968) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 421336569) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 421336569) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2362912767) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[22216] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"503" <sip:503@130.193.62.54>' failed for '138.68.164.151:5135' (callid: 2362912767) - Failed to authenticate
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3709979522) - No matching endpoint found
[2023-05-03 13:27:33] NOTICE[1005] res_pjsip/pjsip_distributor.c: Request 'REGISTER' from '"511" <sip:511@130.193.62.54>' failed for '64.226.116.156:5271' (callid: 3709979522) - Failed to authenticate
i thinks DNS !
следует анализировать дамп трафика SIP
Приходит ли INVITE при входящем звонке?
