[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "--- Incoming call ---") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:2] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "CHANNEL(language)=ru-ru") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:3] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "CHANNEL(hangup_handler_wipe)=hangup_handler,s,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:4] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "__FROM_DID=2100000") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:5] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "__FROM_CHAN=PJSIP/SIP-TRUNK-2585B1E7-00000006") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:6] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "__M_CALLID=[C-00000005]") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:7] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "1?Gosub(set_from_peer,s,1)") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx_lua.c: Executing [s@set_from_peer:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "__FROM_PEER set to SIP-TRUNK-2585B1E7")
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx_lua.c: Executing [s@set_from_peer:1] return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "")
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:8] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?Set(__FROM_PEER=79029100004)") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:9] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "add-trim-prefix-clid,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@add-trim-prefix-clid:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "--- Incoming call from 79029100004 ---") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@add-trim-prefix-clid:2] GosubIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?add-trim-prefix-clid-custom,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@add-trim-prefix-clid:3] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:10] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "__TRANSFER_OPTIONS=t") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:11] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "contextID: 188234136495060-incoming") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:12] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?Set(contextID=none-incoming)") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:13] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?Set(contextID=SIP-TRUNK-2585B1E7-incoming)") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:14] GosubIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "1?check-out-work-time,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:1] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "currentYear=2024") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:2] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "check-out-work-time-9,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-9:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-9:2] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "18:00-23:59,mon-fri,*,*?work-time-set-var-9,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-9:3] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "00:00-10:00,mon-fri,*,*?work-time-set-var-9,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-9:4] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:3] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "check-out-work-time-13,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-13:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-13:2] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "16:00-23:59,sat-mon,*,*?work-time-set-var-13,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-13:3] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "00:00-10:00,sat-mon,*,*?work-time-set-var-13,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-13:4] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:4] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "check-out-work-time-12,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-12:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-12:2] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "*,sun-sun,*,*?work-time-set-var-12,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-12:3] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:5] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "check-out-work-time-6,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-6:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-6:2] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "TMP_YEARS=2025-") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-6:3] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?return") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-6:4] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "*,*,1-3,jan-jan?work-time-set-var-6,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-6:5] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:6] Gosub("PJSIP/SIP-TRUNK-2585B1E7-00000006", "check-out-work-time-5,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-5:1] NoOp("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-5:2] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "TMP_YEARS=2025-") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-5:3] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?return") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-5:4] GotoIfTime("PJSIP/SIP-TRUNK-2585B1E7-00000006", "*,*,8-8,mar-mar?work-time-set-var-5,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time-5:5] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@check-out-work-time:7] Return("PJSIP/SIP-TRUNK-2585B1E7-00000006", "") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:15] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "IN_NEED_ANNONCE=1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:16] GosubIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "0?SIP-TRUNK-2585B1E7-incoming-custom,2100000,1") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:17] Set("PJSIP/SIP-TRUNK-2585B1E7-00000006", "M_TIMEOUT=30") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] pbx.c: Executing [2100000@SIP-TRUNK-2585B1E7-incoming:18] ExecIf("PJSIP/SIP-TRUNK-2585B1E7-00000006", "1?Dial(Local/2001@internal-incoming,30,tKg)") in new stack
[2024-08-09 10:16:04] VERBOSE[10854][C-00000005] app_dial.c: Called Local/2001@internal-incoming
[2024-08-09 10:16:04] VERBOSE[10856][C-00000005] pbx.c: Executing [2001@internal-incoming:1] ExecIf("Local/2001@internal-incoming-00000003;2", "1?Set(TIMEOUT(absolute)=30)") in new stack
[2024-08-09 10:16:04] VERBOSE[10856][C-00000005] func_timeout.c: Channel will hangup at 2024-08-09 10:16:34.379 +07.
