Нет звука , SRTCP unprotect failed on SSRC 1176573248 because of unable to perform desired validation
Развернул img образ в digitalocean . На фаерволе разрешил порты UDP 10000-10800. Но голоса не слышно
MIKOPBX ver: 2022.3.15
В логах след.
[2023-02-26 01:31:18] DEBUG[7532]: cel_beanstalkd.c:152 cel_bs_put: Successfully created job 663 with {"EventName":"USER_DEFINED","AccountCode":"","CallerIDnum":"100","CallerIDname":"Artem Goncharenko","CallerIDani":"100","CallerIDrdnis":"","CallerIDdnid":"777","Exten":"s","Context":"hangup_chan","Channel":"PJSIP/100-0000000c","Application":"CELGenUserEvent","AppData":"eyJPTERfTElOS0VESUQiOiJtaWtvcGJ4LTE2NzczNjA2MzcuMTIiLCJVTklRVUVJRCI6Im1pa29wYngtMTY3NzM2MDYzNy4xMl9MdjBBOTQiLCJWTVNUQVRVUyI6IiIsImFjdGlvbiI6Imhhbmd1cF9jaGFuIiwiYWdpX2NoYW5uZWwiOiJQSlNJUC8xMDAtMDAwMDAwMGMiLCJhZ2lfdGhyZWFkaWQiOiJtaWtvcGJ4LTE2NzczNjA2MzcuMTJfQjQ4MGxLIiwiZGlhbHN0YXR1cyI6IkFOU1dFUkVEIiwiZGlkIjoiIiwiZW5kIjoiMjAyMy0wMi0yNiAwMTozMToxOC4zNDIiLCJsaW5rZWRpZCI6Im1pa29wYngtMTY3NzM2MDYzNy4xMiIsInNyY19udW0iOiIxMDAifQ==","EventTime":"2023-02-26 01:31:18","AMAFlags":"DOCUMENTATION","UniqueID":"mikopbx-1677360637.12","LinkedID":"mikopbx-1677360637.12","Userfield":"","Peer":"","PeerAccount":"","Extra":"{\"extra\":\"\"}"}
[2023-02-26 01:31:18] DEBUG[7532]: cel_beanstalkd.c:152 cel_bs_put: Successfully created job 664 with {"EventName":"USER_DEFINED","AccountCode":"","CallerIDnum":"777","CallerIDname":"777","CallerIDani":"777","CallerIDrdnis":"","CallerIDdnid":"","Exten":"s","Context":"hangup_chan","Channel":"PJSIP/777-0000000d","Application":"CELGenUserEvent","AppData":"eyJPTERfTElOS0VESUQiOiJtaWtvcGJ4LTE2NzczNjA2MzcuMTIiLCJVTklRVUVJRCI6Im1pa29wYngtMTY3NzM2MDYzNy4xMl9MdjBBOTQiLCJWTVNUQVRVUyI6IiIsImFjdGlvbiI6Imhhbmd1cF9jaGFuIiwiYWdpX2NoYW5uZWwiOiJQSlNJUC83NzctMDAwMDAwMGQiLCJhZ2lfdGhyZWFkaWQiOiJtaWtvcGJ4LTE2NzczNjA2MzcuMTNfMWI1MVRkIiwiZGlhbHN0YXR1cyI6IiIsImRpZCI6IiIsImVuZCI6IjIwMjMtMDItMjYgMDE6MzE6MTguMzQyIiwibGlua2VkaWQiOiJtaWtvcGJ4LTE2NzczNjA2MzcuMTIiLCJzcmNfbnVtIjoiNzc3In0=","EventTime":"2023-02-26 01:31:18","AMAFlags":"DOCUMENTATION","UniqueID":"mikopbx-1677360637.13","LinkedID":"mikopbx-1677360637.12","Userfield":"","Peer":"","PeerAccount":"","Extra":"{\"extra\":\"\"}"}
  == Spawn extension (internal-users, h, 2) exited non-zero on 'PJSIP/100-0000000c'
  == Spawn extension (internal-users, h, 2) exited non-zero on 'PJSIP/777-0000000d'
  == MixMonitor close filestream (mixed)
  == MixMonitor close filestream (read)
  == MixMonitor close filestream (write)
  == End MixMonitor Recording PJSIP/777-0000000d
См. статью:
https://blog.telefon1c.ru/analiz-probliem-so-zvukom/
Скорее всего дело в NAT
Логи прикладываю
