PDOException: SQLSTATE[HY000]: General error: 13 database or disk is full in file /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php on line 263 Stack trace: 1. PDOException->() /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php:263 2. Phalcon\Mvc\Model->save() /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php:263 3. MikoPBX\Common\Models\PbxSettings->setValue() /offload/rootfs/usr/www/src/AdminCabinet/Controllers/GeneralSettingsController.php:309 4. MikoPBX\AdminCabinet\Controllers\GeneralSettingsController->updatePBXSettings() /offload/rootfs/usr/www/src/AdminCabinet/Controllers/GeneralSettingsController.php:127 5. MikoPBX\AdminCabinet\Controllers\GeneralSettingsController->saveAction() [internal]:0 6. Phalcon\Dispatcher\AbstractDispatcher->callActionMethod() [internal]:0 7. Phalcon\Dispatcher\AbstractDispatcher->dispatch() [internal]:0 8. Phalcon\Mvc\Application->handle() /offload/rootfs/usr/www/sites/admin-cabinet/index.php:65 9. Application->main() /offload/rootfs/usr/www/sites/admin-cabinet/index.php:73 PDOException: SQLSTATE[HY000]: General error: 13 database or disk is full in file /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php on line 263 Stack trace: 1. PDOException->() /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php:263 2. Phalcon\Mvc\Model->save() /offload/rootfs/usr/www/src/Common/Models/PbxSettings.php:263 3. MikoPBX\Common\Models\PbxSettings->setValue() /offload/rootfs/usr/www/src/AdminCabinet/Controllers/GeneralSettingsController.php:309 4. MikoPBX\AdminCabinet\Controllers\GeneralSettingsController->updatePBXSettings() /offload/rootfs/usr/www/src/AdminCabinet/Controllers/GeneralSettingsController.php:127 5. MikoPBX\AdminCabinet\Controllers\GeneralSettingsController->saveAction() [internal]:0 6. Phalcon\Dispatcher\AbstractDispatcher->callActionMethod() [internal]:0 7. Phalcon\Dispatcher\AbstractDispatcher->dispatch() [internal]:0 8. Phalcon\Mvc\Application->handle() /offload/rootfs/usr/www/sites/admin-cabinet/index.php:65 9. Application->main() /offload/rootfs/usr/www/sites/admin-cabinet/index.php:73 {“error”:{“type”:“PDOException”,“message”:“SQLSTATE[HY000]: General error: 13 database or disk is full”,“code”:“HY000”,“file”:“/offload/rootfs/usr/www/src/Common/Models/PbxSettings.php”,“line”:263}}
Вариантов масса:
- Недостаточно свободного места на диске.
- Ограничения файловой системы или базы данных.
- Проблемы с правами доступа.
- Файловая система смонтирована в режиме “только для чтения”
Может, что то такое?
Похоже на docker, при запуске контейнера передали некорректный пользовательский ID и идентификатор группы.
- Системный диск 10Г, АТС в работе меньше недели, запись разговоров не ведется.
- Все остальное “из каробки”, АТС развернута под VMWare, системные файлы не правились
