Ростелеком дал транк с именем admin, поменял на цыфры зазвонил но только по маршруту по умолчанию, имеются несколько транков от ростелекома, они нормально видят маршруты, а этот не хочет видеть свой маршрут
[2022-04-13 15:37:10] NOTICE[10334] chan_iax2.c: Ignoring bindport on reload
[2022-04-13 15:37:10] NOTICE[10334] chan_iax2.c: Ignoring bindaddr on reload
[2022-04-13 15:37:10] NOTICE[10334] app_queue.c: queuerules.conf has not changed since it was last loaded. Not taking any action.
[2022-04-13 15:37:10] NOTICE[4789] res_pjsip/pjsip_configuration.c: Couldn't find auth 'REG-AUTH-SIP-1649432007'. Cannot authenticate
[2022-04-13 15:37:10] WARNING[4789] res_pjsip_outbound_authenticator_digest.c: Host: '188.128.112.116:5060': Failed to set authentication credentials
[2022-04-13 15:37:10] WARNING[4789] res_pjsip_outbound_registration.c: Failed to create authenticated REGISTER request to server 'sip:888658.34.rt.ru:5060' from client 'sip:admin@888658.34.rt.ru:5060'
[2022-04-13 15:37:16] Asterisk 16.16.2 built by root @ on a x86_64 running Linux on 2022-02-08 00:10:34 UTC
[2022-04-13 15:37:16] NOTICE[10431] cdr.c: CDR simple logging enabled.
[2022-04-13 15:37:16] NOTICE[4789] sorcery.c: Type 'system' is not reloadable, maintaining previous values
[2022-04-13 15:37:16] NOTICE[10431] chan_iax2.c: Ignoring bindport on reload
[2022-04-13 15:37:16] NOTICE[10431] chan_iax2.c: Ignoring bindaddr on reload
[2022-04-13 15:37:16] NOTICE[10431] app_queue.c: queuerules.conf has not changed since it was last loaded. Not taking any action.
[2022-04-13 15:37:49] NOTICE[4789] res_pjsip_session.c: SIP-1648828947: Call (UDP:188.128.112.116:5060) to extension 'admin' rejected because extension not found in context 'SIP-1648828947-incoming'.
[2022-04-13 15:38:18] NOTICE[4789] res_pjsip_session.c: SIP-1648828947: Call (UDP:188.128.112.116:5060) to extension 'admin' rejected because extension not found in context 'SIP-1648828947-incoming'.
[2022-04-13 15:41:32] NOTICE[4789] res_pjsip_session.c: SIP-1648828947: Call (UDP:188.128.112.116:5060) to extension 'admin' rejected because extension not found in context 'SIP-1648828947-incoming'.
