How does the backup module work in MikoPBX?
The MikoPBX backup module allows you to save:
- System settings
- Call history
- Audio files
- Call recordings
When restoring, it is important to consider the correct disk configuration (system and data disks). In case of problems with media file restoration, it is recommended to create an issue in the ModuleBackup repository on GitHub.
Visit our group for more information:
