Call Parking Timeout Configuration in MikoPBX
How can I increase the call parking time from 45 seconds to a longer duration?
To change the parking time, you need to edit the file /etc/asterisk/res_parking.conf, adding the parameter parkingtime => 60 (where 60 is the desired time in seconds). After making changes, execute the command asterisk -rx’module reload res_parking.so’ to apply the settings. For automation, you can create a shell script that runs via cron.
Visit our group for more information:
