hello, i want to thank you all for making this nice pbx system, this is truley great experience to setup and run mikopbx.
i have setup miko pbx with 2 eth, one connected to my internal server and mikrotik witch has all the extentions, one is for the special wan witch is connected to vlan of VOIP provider, ( vlan 700 is for VOIP and 800 is for internet, on my provider)
i have setup all the ips and managed to register a trunk.
when i try to call to my number, a welcome tune plays, but it wont call the extention as it is determined in my que. extension is registered as well. also outgoing call only beep twice and then it drop the call.
so inbound works, but miko wont call the extension. and outbound wont work, but it shows its registered.
not sure if its because provider wont accept PJSIP or not.
if incoming call was ok, i could at least be sure that miko can make calls on extentions.
something fishy is happening.
