I keep getting the following error message whenever I try to create an image from blob storage
The specified cookie value in VHD footer indicates that disk ‘mikopbx-2026.1.223-x86_64 (1).vhd’ with blob https://mikapbxxxxxxxx:8443/imgs/mikopbx-2026.1.223-x86_64.vhd is not a supported VHD. Disk is expected to have cookie value ‘conectix’. (Code: InvalidParameter, Target: disks)
I am using latest version that I downloaded from the website.
Thanks for the report. I checked the VHD file from our latest releases and can confirm the image itself is a valid Azure-compatible fixed VHD: the footer contains the required conectix cookie, disk type is Fixed (2), virtual size is aligned to
1 MiB, and the footer checksum verifies correctly. So the problem is happening between the download and the Azure import, not in the file we publish.
The most likely causes, in order:
The VHD was uploaded as a Block Blob instead of a Page Blob.
This is by far the most common reason for the exact error you’re seeing. Azure Managed Disk import requires the source blob to be a Page Blob — a Block Blob will fail with the same “cookie value in VHD footer” message even when the file is
perfectly fine.
Please re-upload using one of these commands, which force the correct blob type:
Then create the Managed Disk from that Page Blob (Portal: Create disk → Source type: Storage blob, or az disk create --source ).
The sourceUri points to your own HTTP server.
The URL in your error message — https://mikapbxxxxxxxx:8443/imgs/...vhd — looks like a self-hosted server, not Azure Storage. Azure can only import from a blob URL on *.blob.core.windows.net (with SAS if private). It cannot pull a VHD from an
arbitrary external HTTPS endpoint. The VHD must first be uploaded into Azure Storage as a Page Blob as shown above.
The downloaded file is truncated or corrupted.
Before re-uploading, please verify the file you have locally:
Size must be exactly 630,194,688 bytes for the x86_64 image
ls -la mikopbx-2026.1.223-x86_64.vhd
The last 8 bytes of the file MUST read “conectix”
tail -c 512 mikopbx-2026.1.223-x86_64.vhd | head -c 8 ; echo
Compare SHA256 against the value published in checksum.md5 / release page
sha256sum mikopbx-2026.1.223-x86_64.vhd
If tail -c 512 | head -c 8 does not print conectix, the file was truncated during download — please download it again from our GitHub release page.
Let me know which of the three turns out to be the case and I’ll help you finish the import.
