Hello guys, did you get mobile redirect working? I cannot seem to get it working. The mobile is written under the employee's profile, in correct form (+32(487)xxx-xxx) but whenever a redirect is happening, it just shuts down. MicroSIP is showing "Internal server errror" And in the verbose.log in mikopbx I see this:
[2024-09-20 09:34:14] WARNING[1217466][C-0000000b] func_channel.c: CHANNEL_EXISTS: Channel name or unique ID required
[2024-09-20 09:34:14] VERBOSE[1217466][C-0000000b] pbx_lua.c: Executing [0487XXXXXX@dial:1] NoOp("Local/32487XXXXXX@internal-incoming-0000000d;2", "The channel no longer exists (). We are completing the call.")
Anyone got an idea where I'm going in the wrong?
All calls are working fine (incoming and outgoing). Except forwarding to mobile for an extension does not work.
Example:
My first extension is 700. My second extension is 705 and Mobile is defined as +32(487) XXX-XXX.
- When I call from 700, to the 705 and the 705 is unavailable, it goes correctly to the mobile. The mobile rings are good. ✔
- When I setup incoming routing to redirect all calls to the mobile number, all calls get rejected. Why?
