How to fix WebRTC extension to WebRTC extension calls getting ‘sip/2.0 488 not acceptable here’ error?
The ‘488 not acceptable here’ error typically indicates a codec mismatch between WebRTC endpoints. Check the following: 1) Verify codec compatibility in WebRTC settings 2) Ensure both extensions support common audio codecs 3) Check WebRTC configuration in PJSIP settings. WebRTC usage is limited in MikoPBX, so codec configuration is critical for proper operation.
