How to Configure Alert-Info for Different Types of Calls in MikoPBX?
- In the standard version of MikoPBX, there is no direct way to configure Alert-Info.
- To implement this, you can use customization through the PT1C_SIP_HEADER variable in the provider:
- In additional parameters, specify: [endpoint]
set_var=PT1C_SIP_HEADER=Alert-Info: YOUR_VALUE
- When an incoming call is received, the system will process the header in the dial_create_chan context
Visit our group for more information:
