Setting up Let's Encrypt SSL Certificate in Yandex Cloud
How to fix the Let’s Encrypt SSL issue in Yandex Cloud?
When using MikoPBX in Yandex Cloud with DDoS protection enabled, you need to:
  1. Set MTU to 1450 bytes
  2. Set TCP MSS to 1410
    Alternative solution - disable DDoS protection. The problem is related to incorrect network settings when DDoS protection is enabled.
Visit our group for more information:
