Hello, is there a workaround to register the mikopbx at tel.t-online.de ?
based on this information it does not work https://www.telekom.de/hilfe/werksreset-speedport/werksreset-faq/einrichtung-sip-client?samChecked=true
phonenumber@t-online.de there seem to be problems for the busername
1and1 it went without problems
Thanks in advance
MfG Marcel
Hello, In the Username field, you need to enter your SIP ID (phone number). If the authentication name is different from the SIP ID, you can specify it in the Advanced Options field, for example like this:
[registration-auth] username=phonenumber@t-online.de [endpoint-auth] username=phonenumber@t-online.de
